Does anyone out there use a standard “per square” factor when bidding vinyl siding jobs? If so how much and where. How about “cost of material times ____?”
Prescriptive codes don't address the connection at less common angles, so base the connection off more typical ones using bolts, structural screws, blocking, and steel tension ties.
250 per square for material and labor complete direct contracted job.
near the stream,
aj
materials times 2.67
