Cost of treated PSL beams vs. plywood
gb62 | Posted in General Discussion on April 26, 2009 10:20am
I am an owner-GC reviewing my lumberyard’s prices on the takeoff for the first phase: posts, drop beams, flush beams, joists, hardware (gobs of Simpson hardware), and deck. Can anyone point me to an online resource to help me see if his prices are reasonable?
In particular, I’m wondering about his pricing for treated PSL beams. I would have thought these would be only a little more expensive per unit volume than a high-grade plywood.
4×8 3/4″ T&G Advantech (2 cu. ft of lumber): ~$31
3 1/2″ x 16″ x 1′ PSL Treated (0.389 cu. ft of lumber): ~$34
So my cost per cu ft for the PSL is 5.6x the cost of the Advantech!
Is that what I need to expect? Are treated PSL beams such a low-volume material that I have to pay such a hefty premium? Or is there some other reason?
  1. Hiker | Apr 27, 2009 01:05am | #1
    I believe PSL technology is owned by Weyerhaueser and therefore they can charge what they want.  They are also limiting production of the product and are not making it easy for yards to sell the stuff.
    The treated PSL is through the roof.  Comparing plywood to PSL is an apples and oranges comparison.
    Good luck on your project.
    Bruce
  2. windwash | Apr 27, 2009 02:51am | #2
    Here in the twin cities (MN), a 5-1/4"x5-1/4"x10' treated is about $200.00 and untreated is about $115.00 so I'm guessing treating this stuff is quite expensive.
    About 3-4 years ago we used a 14' treated PSL beam about the size you described (might have been 5-1/2" wide) and I think it was close to a grand............ so close to $75/ft. I don't know what the beam prices are now.
    Three 2x12x14's with vycor on the top is about 100.00/material.....big difference in price!
    I like to use the treated PSL posts instead of treated pine for short posts (less than 12") on decks and porches because they don't crack and split.
  3. gzajac | Apr 27, 2009 02:58am | #3
    GB
    last years price in march
    5 1/4 x 11 7/8 31.98/foot
    5 1/4 x 14 37.20/foot
    This was quantity pricing -3000 feet plus.
    No way to compare advantech and PSL pressure treated beams- two different animals Try pricing Simpson stainless hardware- hope you are sitting down.
    Greg in Connecticut
    Matt | Apr 27, 2009 03:11am | #4
    That was quite imaginative to compare the cu ft price of plywood (OSB) to PSL beams.... :-)
    The way to check pricing is to get another yard to price the lumber package for you.  You will probably find one yard to be a little higher on some items, yet a little lower on others.  That's why you need to price it by the package.  Really, you should be pricing the entire house framing package, and then take it phased deliveries unless this thing is gonna take you two or 4 months to frame.... :-)
    1. dovetail97128 | Apr 27, 2009 03:24am | #5
      Addressed to you but meant for anybody interested. I have 3- 3 1/2" x 14" x 20' treated PSL sitting in my yard I will sell at way less than the yard rate. Anybody in the PNW interested drop me a line.
    2. gb62 | Apr 27, 2009 04:28am | #6
      Similar epoxy, similar wood product, similar preservative - ought to be similar price. The advantech is certainly a commodity. Apparently the PSL is not.
      What about LVLs? Maybe just as strong but no Weyerhaueser premium?
        Matt | Apr 28, 2009 01:37am | #7
        I bought some LVLs 2 weeks ago.  Looking back at the bids, the 16" were ~$4.50 per lin ft.  (1.75" x 16").  Lumber prices are very regional.
        Really though, if your plans spec PSL, I think that is what you have use.  Either that, or get an engineer to OK the change - which wouldn't result in any savings at all, unless your engineer does free-bees.  Here, inspectors want changes like that on a stamped letter- those don't come free.
        Again - you need to price this stuff with multiple yards.  You wanted to be the GC - so, do your job!  There is a reason guys like me get paid to do this stuff.
        1. gzajac | Apr 29, 2009 02:49am | #8
          MattI think he needed Pressure treated PSL, a little pricier than normal PSL, or two pieces of 16" LVL.Greg in Connecticut
            Matt | Apr 29, 2009 02:13pm | #9
            Thanks - I missed that.  Not sure I've ever seen one of those.  Where would you use those?   I'm thinking maybe a double window or 6-0 door but normally those would be going in a regular framed wall what wouldn't need treated.  Or, maybe a dropped girder in a very low crawl space...  I could see it on an exterior project like a deck but it sounds like he is building a house.
          2. gzajac | Apr 29, 2009 02:33pm | #11
            MattI've only come across them once, and it was for a large deck project, beam pricing exceeded $100,000. Didn't get the job, but it was an education in bidding.Greg in Connecticut
          3. gb62 | Apr 29, 2009 02:42pm | #12
            After a couple days of email exchanges with my lumber yard, engineer, and architect, we have identified and the engineer has approved the use of a different vendor for our PSL beams at about 60% of the cost. The alternate beams are Anthony Treated Power Preserved 24F-V5M1 Glulams.
            Yippee.
        Matt | Apr 29, 2009 02:16pm | #10
        Where are the treated PSLs to be used?
        1. gb62 | Apr 29, 2009 02:44pm | #13
          As a support structure between piers and the house's flush framing. The engineer wants PSL because of the moisture issues - bare ground just a few feet away.
            Matt | Apr 29, 2009 03:23pm | #14
            Hummm...
            Here code says that girders don't have to be treated unless they are less than 12" to the grade, joists 18".  We are in the termite belt too.  I'd never build anything any lower because tradesmen need to get access - plumbers, electricians, HVAC guys, etc.  BTW - we are on IRC 2006.
            Maybe your in a costal area or other damp environment?
            Matt | May 02, 2009 02:00pm | #15
            I was at my building supply yesterday and asked my salesmen who has been selling lumber for 30 years about PT LVLs and PSLs.  He said: "I can order them.  There is not much call for them so we don't stock them."  It's the largest building supply in this medium sized city.
          3. gb62 | May 03, 2009 12:41am | #16
            The PSL beams are to be layed on piers and a 1.5 story house layed on top of the beams. I'm stuck with piers because site conditions make both a basement and a slab unworkable. A house with either of those would have no nead for PSL beams. Oh, and did I mention my beams have to be light enough for a gaggle of men to handle by hand? And light enough to take across a lake on a barge? What a project...
  5. ktkcad | Dec 30, 2019 07:26pm | #17
    10+-year-old question and comments...
    2020 update:
    "Pressure Treatment" for PSLs is still typically a third party process and shipping to and from very few beams sized treatment facilities is added expense. Then, because PSLs are significantly filled with glues (you have to see them built in the factory to appreciate how much glue is in them) there isn't much room for the 'pressure treatment' to go into the 'wood' so it isn't all that effective. This came from my Weyerhaeuser rep. Same for all lsl, lvl psl engineered beams.
    Some day they may have glues with moisture and termite resistance built-in but don't hold your breath for it.
