Cove Ceiling
Timuhler | Posted in Photo Gallery on March 13, 2003 01:55am
Here are some pictures of some work I did over the last day and a half.  Let me know what you think.
Any pointers anyone can give me is appreciated.  I’d like to hear from someone who has framed a cove before.  Does it look like I have enough backing in the inside corners of the cove?
This is the first time I’ve framed one of these, so I would appreciate any advice you guys have.
The monster arch took 4 guys to lift into place.  It was quite heavy and the ceilings are 9′, so it wasn’t fun to put in, but it looks good.
  1. Piffin | Mar 13, 2003 05:37am | #1
    I've done three like this one with a smooth radius instead of the elliptical and i find that I can get by with blocking at about 12" OC instead of solids like you framed it.
    The tighter the radius, the closer you need the blocking
    1. Piffin | Mar 13, 2003 05:40am | #2
      let's try it again....
        Timuhler | Mar 13, 2003 05:51am | #3
        Thanks for replying.  I used to put in a lot less backing, but the taper we were using was complaining that there wasn't enough backing for him the make that bend at the bottoms of the arch.  Now I just use up scrap so I don't have to listen to him whine.
  2. DaveHeinlein | Mar 13, 2003 05:56am | #4
    When I've built a large arch like yours, I cut the plywood arches together on horses, then tacked them in place and did the 2x infilling afterwords. No heavy lifting.
    The cove on the cieling I have done by splitting plastic water pipe(12") on a bandsaw, then veneering with a fancy wood. It worked quite nicely, and minimal framing was needed behind it.
  3. JohnSprung | Mar 21, 2003 02:29am | #5
    The way mine was done back in 1926 was that they ran the horizontal lath from the first direction a little past the inside corner, and then brought the lath from the second direction up close to it.  Then they ran a little expanded metal over the corner before plastering.  I hate having to demo those to do termite repair, because I know it won't be easy putting them back.
    -- J.S.
      Timuhler | Mar 21, 2003 03:28am | #6
      Thanks John.  When I do this again, it'll be a bigger radius and I'll have learned (at least a little) how to do this better.  Thanks for your suggestion.
