cove molding angles
louie | Posted in Construction Techniques on December 18, 2010 02:46am
i just made some cove on the table saw.  what angles should i cut the back at?  i am trying to match some existing cove on a mantle and it looks like it is just 45 degrees.
  1. DanH | Dec 18, 2010 03:45pm | #1
    You're talking about the triangular section that "isn't there" on the back of most cove molding?  That's primarily to conserve materials, but also to lighten the pieces, reduce curling/cracking, and avoid problems with slightly-rounded ceiling corners.  No special angle, unless you're using angled blocks behind to support the stuff.
  2. ChicagoMike | Dec 18, 2010 08:42pm | #2
    Just match what is there. If it is 45 degrees, cut it 45 degrees.
