Cover ragged light fixture ceiling hole?
tab1 | Posted in General Discussion on November 1, 2009 06:38am
Let’s just say someone were to make a hole in the ceiling a bit larger than the fixture base. Ceiling is old stapled up white tiles.
Is there a relatively easy way to cover this? I’ve thought of cutting a disc of either thin wood or metal, to place between the fixture and the ceiling, but maybe there’s a ready made solution?
Doesn’t need to look really good, as the tiles certainly don’t!
Thanks.
  1. Danno | Nov 01, 2009 06:47pm | #1
    At home centers there are decorative plastic escutcheons that are supposed to look like plaster that go around light fixtures--one of those may be large enough to cover your problem.
    Edit--IMERC had the right word for it--rosette, not escutcheon. (I also want to call them "medallions).
    Edited 11/1/2009 3:57 pm ET by Danno
    IMERC | Nov 01, 2009 07:20pm | #2
    a rosette from a BB in the lighting/fan departments...
    WOW!!! What a Ride!
    Dam_inspector | Nov 01, 2009 07:28pm | #3
    Get a bigger fixture.
  4. DanH | Nov 02, 2009 04:14am | #4
    Get a "medallion" to put above the fixture: http://www.lightingdirect.com/index.cfm?page=search:browse&categoryID=14943
    A strong nation, like a strong person, can afford to be gentle, firm, thoughtful, and restrained. It can afford to extend a helping hand to others. It's a weak nation, like a weak person, that must behave with bluster and boasting and rashness and other signs of insecurity. --Jimmy Carter
    1. tab1 | Nov 02, 2009 04:47pm | #5
      Thanks--just the info I needed.
