Covering Z flash
GCNC | Posted in Construction Techniques on March 20, 2005 01:01am
Hi
I usually leave Z flash exposed and paint to match siding. I have seen some houses that have horizontal boards covering the flashing. Technically the lip of the flashing should go over the board but it looks like they just covered it over. Anyone have experience with doing this? I may call the inspection dept to see if they will haslle me about it. If I cover it, I will rip a slope into the top of the horizontal trim and cauk like mad.
HC
  1. Piffin | Mar 20, 2005 01:24am | #1
    I can think of at least three ways to use Z flash for diff things. Where is this? Door and window heads?
    1. GCNC | Mar 20, 2005 02:12pm | #10
      The Z flash is on RS ply with verticle 1x6 battens. Gable ends are most exposed
      HC
  2. Mitremike | Mar 20, 2005 01:32am | #2
    I used z flash on my T1-11 for my shed and if they just cover it over it rot out the back of the cover board in no time because the valley lines in it are blocked by the flash and create pools of water.
    It the siding is smooth I think that you could install the flash and move the downhill edge out a little to catch the top of your beveled cover board.
    As piffin says there are other ways to use the stuff but these are the two that come to mind.
    Mike
  3. Piffin | Mar 20, 2005 02:27am | #3
    If for a seam in T1-11, I would not cover it.
    1. Mitremike | Mar 20, 2005 06:07am | #4
      I know what you are saying and I didn't cover mine --mostly because I didn't want to cut down each sheet just to get the seam to land in line with the horz. banding on the gable ends.And also because I saw the problem with the vert lines being blocked by the z flash.Once I painnted the shed with its transom window and other details I really didn't care if you could find the z flash --after all it was the same color as the wall anyways.Mike
    2. Mitremike | Mar 20, 2005 06:10am | #5
      Hey Piffin, Can I have your 20,000 post?At the rate you are going it should only be a couple of weeks. Or less. I'll give you a cold beverage of choice at the first rally we meet at...MIke#328
      1. Piffin | Mar 20, 2005 06:52am | #6
        jeeze, didn't know the count was that high! Whatcha mean, "have it" ???
        LIKE - ADRESS IT TO YOU?Whadya bid? LOL
        1. davidmeiland | Mar 20, 2005 06:59am | #7
          You could put the 20,000th post up for auction. High bidder's choice of thread and recipient. Wouldn't be any stranger than the adult actress who auctioned off her K cups.
          1. Mitremike | Mar 20, 2005 08:51am | #9
            I'll trade you my #330 for your # 1892......Mike
        2. Mitremike | Mar 20, 2005 08:49am | #8
          Piffin, You got it---Send it to me and I'll personally serve you a cold or warm beverage of your choice on a silver platter at the first event that we get to meet at.I know everyone gonna jump on my bandwagon and start outbidding me and thats fine--Just remember I asked first and started the whole thing.So no dots......No white spaceNo zooming jets, or winnie-the-pooh on a stick or any other fanfare just a polite please, thank you and a beverage served with a hand shake and a " fine to meet you " Mike
          1. Piffin | Mar 20, 2005 04:32pm | #11
            Since you asked, niocely, I have a sticky note on my monitor that says mitremike 20,000Somebody out there - I forget who - has my adress to send a promised hand carved wood plaque from my 5,000 post aniversary.
            Oh well...
          2. Mitremike | Mar 20, 2005 10:18pm | #12
            Maybe I should make a maple serving tray instead of silver. :)Since joining last summer I haven't had the chance to meet anyone from BT but I am looking seriously into the aug. dates but may have a marrriage in the family..We are having one in Aug just the date hasen't been set.I don't care what they pick---but I'll steer them away from the 12thThank you and look forward to meeting you and the others soon.Mitremike
