CPVC Plumbing question
bchanson | Posted in General Discussion on February 23, 2006 07:51am
What may be a silly question here from someone non-initiated with CPVC for residential plumbing. I’m not a plumber, but do re-plumb small bits here and there during the course of remodels. Always have used copper. Current project poses some problems with existing wiring to sweating pipes. I will use plastic but had a funny thought today about the stub-outs for WC and bathroom sink and a claw-foot tub in bathroom. Is there any reason not to use the plastic for the stubouts? Will angle stops with compression fittings work as usual as with copper. Is there any reason to switch to copper for the stubouts?
Just curious so thought I’d ask.
thanks.
Brad
  1. DanH | Feb 23, 2006 07:59am | #1
    The obvious reasons:
    --CPVC is much easier to damage when exposed.
    --CPVC flexes too easily to support twisting a valve.
    --CPVC looks like carp.
    --CPVC will not (in general) accept fittings designed for copper. (In particular, do not use a compression fitting designed for copper, as the plastic will decide to change diameter at an inconvenient time and take leave of the fitting.)
    happy?
    1. dgbldr | Feb 23, 2006 09:26am | #2
      Nah, more like salmon...
      DG/Builder
    2. bchanson | Feb 23, 2006 10:01am | #3
      so, the solution is to run CPVC to just behind the wall and then stub out copper? I was wondering about that.
      1. DanH | Feb 23, 2006 03:45pm | #4
        I think that's the better solution. Or stub out with brass,, if you want to get fancy.
        happy?
  2. Brooks | Feb 23, 2006 04:49pm | #5
    They make heat-resistant protective pads that you use to protect the wires while soldering. I use them - they work great. They even stand up to mapp gas. BTW, I like mapp gas - you spend a lot less time cooking the pipe.
    I don't like plastic pipes...
    1. DonK | Feb 23, 2006 07:36pm | #6
      How about a picture or a link? I've never seen these. I usually use an old pice of metal as a shield.
      I'm with you though, don't much care for plastic water lines.
      Don K.
      EJG Homes     Renovations - New Construction - Rentals
      1. Brooks | Feb 23, 2006 07:44pm | #7
        I buy them at HD. They're probably available at plumbing supply houses as well. I haven't left burnt studs since I got a couple.
  3. csnow | Feb 23, 2006 08:14pm | #8
    You need to use the special CPVC <-> Copper transition fittings.
    Especially important for the hot side.
    These fittings are rather expensive, so they eat into your material savings.
    Another alternative might be to use threaded copper or brass fittings where you do not want to torch.  You know- old school...
    PEX is yet another option.
  • A Postwar Comeback
  • Natural Simplicity
  • A Grand Rescue on the Coast
