I am concidering using CPVC in my new house for hot & cold supply water.
Why is it that homes being built today are not using CPVC for hot & cold water supply?
What are the downfalls of using CPVC?
Will it last as long as copper?
Is the plastics expansion and contraction rate a problem?
Because it is so flexable, does it need to be installed in a special way?
I have also heard about a health problem (cancer), is this true?
The most common way to make your own parging mix is to use either Type S mortar for block or Type N for brick and add a concrete bonding additive.
Search the archives. CPVC has been discussed. Start < Obsolete Link > here. One advantage to CPVC is that is does not spring a leak as easily under freezing conditions.
Look into PEX also.
*Gertlea,You may also want to check out plbg.com. Enter CPVC in the search box to find several good posts about cpvc vs copper.regards, jiml
Gertlea, check with your local building department, too. CPVC doesn't meet code here, although it is available.
