cracked tub
cutawooda | Posted in General Discussion on July 31, 2003 08:12am
Just cleaned my tub 2 months after the install. Full of insulation and dirt. Let me add that I knew better,…I KNEW BETTER!!! but I did not cover it and protects it. So, after I cleaned it I almost threw-up. ….a 4 inch crack in the porcelain. I have no idea who did it and it would be a waste of time trying to pin it on anyone…bottom line is that it was my fault for not protecting it. It could have been anyone of 4 trades.
What is my solution…it is tiled already. Does the porcelain patch really work?
    Luka | Jul 31, 2003 08:27am | #1
    Just put some bondo on it.
    Quittin' Time
    SamT | Jul 31, 2003 11:08am | #2
    Yeah it works, BUT...not a DIY project. Prep includes use of an acid and for new construction pay the pro.
    SamT
    "Law reflects, but in no sense determines the moral worth of a society.... The better the society, the less law there will be. In Heaven, there will be no law, and the lion will lie down with the lamb.... The worse the society, the more law there will be. In Hell, there will be nothing but law, and due process will be meticulously observed."
    Grant Gilmore, The Ages of American Law (New Haven: Yale University Press, 1977), pp. 110-111.
    From 32866.117
  3. KARLSTER | Aug 01, 2003 09:23am | #3
    I was making templates for some vanity tops while a tilesetter was doing tub surrounds.  Two of the tubs had dime sized chips out of the porcelain/enamel/whatever it is.  I was dumbfounded they were continuing to tile around the damaged tubs in a million dollar home.  I kept my mouth shut to avoid invoking the wrath of whoever had created the chips.
    When I showed up the next day to make the kitchen countertop templates I poked my head in the bath and saw a beautifully grouted tile job and a sparkling clean chip free tub???
    I asked the tile setter about it and he gave me a card for the chip repair guy who did the repairs.  The color match was absolutely perfect and it was filled and then final coated with epoxy paint.  Personally I don't think epoxy coatings will hold up as well as the original but the tile setter will be long gone by the time it becomes an issue.
    Call a local plumbing supplier and see if they can't hook you up with your local specialist in tub chip repair.
    Good luck, karl
    1. Scooter1 | Aug 01, 2003 06:52pm | #4
      Just subbed out a porceline re-glaze and while I was hanging doors got to see the process.
      It is about a 6 hour deal-1-2 hours taking off plumbing and taping and screening the area for spraying; 1-2 hours for sanding, cleaning, stripping and prepping; and 1-2 hours for spraying a bonding coat, fill coats, and a top coat. At least a 72 hour curing period, and a week is better. Tub looks new. Price was $500.
      Regards,
      Boris
      "Sir, I may be drunk, but you're crazy, and I'll be sober tomorrow" -- WC Fields, "Its a Gift" 1934
Choosing a Paintbrush
  • The New Old Colonial
