38522.1 | |
just built a new home, did alot of it myself and i am very happy with it. However, I have noticed two areas by the fireplace and window next to the fireplace with cracks through the brick. Today I noticed that the two bricks on the fireplace hearth have cracked,..one throught the brick and the other on its joint. What caused brick to crack through like that. The slab under neath them is not cracked there. The first palce i noticed was at the window outside…I blew it off to a little settling..now it is running the horizontal joint for 4 bricks. But the slab is not cracked there. Logically, if there is a seperation of the bricks, there should be a crack in the slab..Am I wrong? Granted, we are very dry right now..but I still want to know what causes a brick to crack down its middle..what forces are at play here. thanks |
If not settleing foundatiopn, my first guess is that there was a high portland content in the mortar. That makes for a much harder and more brittle job. The older mortars were higher in lime which is somewhat flexable, and self healing.
The individual brick - any brick can crack. It may have been an underlying invisible fracture when laid but the stress of loading, shrinking, and fires could expose it.
I'm sure there are more things too.
I am no genius....boy! thats for sure...explain to me the theory,..no,.not theory, the chronilogical order of things as they occur during settling. What I am getting at is this:
What causes those famous cracks you see in homes that zig zag diagonally through the bricks. Is it movement from twisting, sheering, or has the slab cracked close to that point. And if the latter is the case, would you not be able to see the crack around the perimeter somewhere. I dont mean to get particular and waste your time..but I am truly curious about my bricks cracking. I am, as you would expect, upset to see my bricks cracking. I know that this clay soil and dry weather are the culpret, but I am still trying to analyze this situation. I appreciate your response, as well as your other responses on different issues.
Zig Zag or stair step?
Probably stair step following the mortar joints. This would be from foundation movement or settling. You might not see a crack in the slab/footing. Developing a very slight crown from settling can parlay into a pattern like that..
so, concrete bends?
cuta,
everything bends, some, not so you would notice, some, like rubber.
SamT
Darn right it bends.
When you first mix it, it bends really good. It'll even bend enough to run through a pumper hose or let you use tools to push it around.
That is when it is in the plastic state.
But it doesn't cure in an instant, Bif Powie done!
It is a long slow process. Not uncommon at all to pour and then build over it while still only seventy percent of design strength. So you are adding weight to it as it cures slowly. If you built over clay sol and it is drying/shrinking at the same time, the soil under is moving - possibly unevenly - while the weight is being added above. So it bends. Sometimes it doesn't bend so much, and it cracks instead.
Concrete is an amazing product. Did you know there have been concrete canoes built that do better than ABS ones?.
Article on concrete racing canoes:
http://www.schundler.com/canoe.htm
My office at UC was next to the building where they constructed these things:
http://www.ce.berkeley.edu/~canoe/
The cracks are almost certainly caused by settlement but you ought to check if the structure is still moving. The best way is to use a small strip of glass across the crack, fixed with epoxy glue, so that any further movement breaks the glass.Concrete does flex but if the sub-base was consolidated properly the slab shouldn't deflect.Was the fireplace brickwork tied back into the exterior wall?
IanDG
no. and the hearth is merely bricks laid on the slab
