Craftsman “Professional” Air Compressor
69STINGRAY | Posted in Tools for Home Building on September 18, 2005 01:40am
I was at the local Sears today and they had a “used” “Professional Grade” air compressor on sale for $240 (reg. is $399).  I have been wanting one for a while and thought this might be a good chance.  What do people think of this compressor?  Anyone own one? I will be using it for finish nailing, some HVLP painting, grinder and maybe an impact wrench. Automotive and Household chores.  I am thinking of walking in and just offering $199 to see what they say.
sears
  1. Notchman | Sep 18, 2005 03:05am | #1
    IMO, Sears no longer offers anything that would be considered "professional."
    I say that having been a construction millwright for a number of years and bought (and still have) a lot of Craftsman tools (70's vintage and earlier) that are still in great shape.  With that experience, I bought some odds and ends of their stuff in more recent years and, without exception, all have been of less than professional quality.
    Now, and in the future, I will enter one of their stores only to use their restroom (and if I'm carrying my own toilet paper).
    If you want a decent "professional" compressor, I'd encourage you to look at the Makitas....oil bath, quiet, (heavy as a dead priest), but about $189 for a single tank that would do most of your work, or $289 for a twin tank.
  2. MrBill | Sep 18, 2005 03:34am | #2
    Sting,
     I dont think there are very many compressors made today with a cast iron pump, which is the only drawback I see to this one. I have an old (1973 ?) 2 1/2 hp / 20 gal Sears compressor that has never given me a single problem. I have painted several cars with it and used it fairly rgularly for the same type of things you are planning. I think it will be fine for your use.
     Make sure you change the oil yearly, and drain the tank every time you use it. I attribute those two items to the long life of mine.
    Bill Koustenis
    Advanced Automotive Machine
    Waldorf Md
    intrepidcat | Sep 18, 2005 08:50am | #3
    Aww, be a trooper and offer $200.
    Should be worth it.
    We are all in the gutter but some of us are looking at the stars.
  4. daFarmerDave | Sep 20, 2005 02:13am | #4
    Over the years I've had above average luck with Sears stuff.  One electric stapler sucked.  Other than than that, I've been happy.  I  think that looks like a well made machine.  IIRC the tank is ASME certified.  If it's for a heavy duty DIY, I think you should buy it today.
    Big Macs - 99 cents
      MarkH | Sep 20, 2005 03:46am | #5
      My old craftsman cast iron compressor has been running for 27 years. Had to replace the unloader valve, rebuilt the pressure regulator, new ball drain cock, a couple oil changes, new pressure switch.
      1. daFarmerDave | Sep 20, 2005 08:42pm | #6
        How many PSI is it and how long does it take to fill the tank from empty?Big Macs - 99 cents
          MarkH | Sep 20, 2005 09:01pm | #7
          It's a 20 gallon tank. Cast iron two cylinder, 100 psi. Takes a little while to pump up, never measured it. True 1 hp motor, but specs say it pumps the same cfm at 90 psi as the ones that are rated at 5 hp.  My hotdog pumps to 125, but not a lot of cfm and has only a 2 gallon tank, but it's WAY lighter than the old craftsman.
          1. daFarmerDave | Sep 21, 2005 08:11pm | #8
            The makers got their butts hauled into court over the bogus HP ratings.  If you look at how much power they can bring in ( 20Amp at 120Volt )  that's 2400 watts.  At 746 watt per horse power about 2 hp is the best they can do.
            If I was wanting a stationary comp, I'd get a 230 or 208 Volt model.  I got a yellow hand carry, but I suspect it's only good for pnuematic fasteners, inflating and the blow gun.  It might be big enough for a 3/8 ratchet, but I haven't tried mine, yet.Big Macs - 99 cents
          2. shearwater | Sep 21, 2005 11:46pm | #9
            Just make sure it's got the PSI and cfm to drive the tools you want to use ... I've got one of these -- well it's actually 25 years older -- my father in law used it for years to spray furniture.  It would not power a framing nailer -- so I went out and got a 2-tank Hitachi for $279.
          3. Piffin | Sep 22, 2005 12:29am | #10
            I was thinking the same thing about the volumn prodeced. An HVLP is a high VLOUMN user
