Crawlspace Door
RhondaRay | Posted in General Discussion on February 22, 2008 03:28am
We are working with a GC to build our stick-built, 2600 sq ft, single level home over a conditioned (ventless) crawlspace and need a metal or composite crawlspace door, approximately 36″ square.
North Carolina Building Code stipulates that the door be a minimum R2 rating.
Any suggestions?
    MrSQL | Feb 22, 2008 09:20pm | #1
    I have similar crawlspace.  I made my door out of plywood and 1x4's (stained with exterior eurethane) with 1.5 in insulation board on the inside [pressure treated 2x6 jamb and Sill].  Passed inspection in Caswell County, NC.   You could try cutting a store bought steel door if you need steel, or putting a sheetmetal skin on a door that you make/insulate.
    Regards,
    Roger
  2. runnerguy | Feb 23, 2008 01:47am | #2
    My mason installed a premade steel door. The frame had "wings" on the side and he just slid it wings into the side grooves in the CMU's that framed the opening.
    It couldn't work better.
    Runnerguy
    Edited 2/22/2008 5:48 pm ET by runnerguy
  3. Snort | Feb 23, 2008 02:03am | #3
    On a taller door, or a sealed crawl, we cut down a fiberglass slab, and site build a weather stripped frame w/ a therma tru type sill.
    Lowe's contractor yard (since you're in NC, I'm assumig there's one near by) can get pvc doors in a pvc frame that pass code.
    Rigid insulation on a weather stripped pt ply door also passes.
    Where in NC are you? I'm in Chapel Hill, and, welcome to the BT zoo.
    Winterlude, Winterlude, my little daisy,
    Winterlude by the telephone wire,
    Winterlude, it's makin' me lazy,
    Come on, sit by the logs in the fire.
    The moonlight reflects from the window
    Where the snowflakes, they cover the sand.
    Come out tonight, ev'rything will be tight,
    Winterlude, this dude thinks you're grand.
Grout-Free Shower Panels
  • A Postwar Comeback
