Crown Installation Question
etemte | Posted in Construction Techniques on December 2, 2006 05:42am
I’m scheduled to install stained crown in a 10 year old house with textured ceilings. I have never had to deal with a textured ceiling before, and would appreciate any suggestions about the best way to remove with this annoying “feature” and get a flat surface to work with. Thanks for your time!
Edited 12/2/2006 11:03 am ET by etemte
    user-14544 | Dec 02, 2006 06:46pm | #1
    depends on the coarseness of the texture.
    for a heavier (cottage cheese or popcorn) texture, I first figure out the setback of the crown being installed, say 2 1/2"...I then either cut a block of wood the same as the setback with a sharp bevel on it, usually 45*.  I then use the new "scraper block" to go along the wall and ceiling and carve out a channel where the crown will set.
    I've also snapped lines with the proper setback and scraped it off with a putty knife. This can be a pain due to crooked or bowed top plates. Just be careful to not get too carried away...patching in the "popcorn" is a pain..not difficult, but a pain nonetheless
    If the texture is being difficult, you can lightly spray it with a mist-style water bottle.  A little goes a long way.
    If the texture is not to much (say an orange peel or knock down style), I just install the trim (pre-stained and poly) and caulk the joint along the ceiling with painters caulk.
    Good luck and congrats on the choice...a little detail like crown molding can really make a room.
    knowledge without experience is just information.... Mark Twain
    Politicians, like diapers, need to be changed often...and for the same reason.  (the rear chrome part of some old guy's car)
    http://www.cobrajem.com
