Crown molding
| Posted in General Discussion on December 23, 2001 03:02am
I’m installing crown in a inset ceiling. 8 sides. The crown is the 52/38 degree crown. Does anyone know the compound angles for mitering. I have the angles for a 90 degree corner but can’t figure out the angles for this one. Other option is coping the corners. This might be best anyway. Anyone have any advice? Thanks.
  1. doug_hubbard | Dec 23, 2001 03:02am | #1
    set the crown against your saw fence as it will sit on the wall- attach an auxillery fence to your saw if necessary- cut it standing up. 360 degrees divided by eight divided by two will get your angles- test pieces- just takes patience
    can't help you with a math solution- that's how I do it- always works out
  2. Stuart_ | Dec 23, 2001 03:02am | #2
    I'm installing crown in a inset ceiling. 8 sides. The crown is the 52/38 degree crown. Does anyone know the compound angles for mitering. I have the angles for a 90 degree corner but can't figure out the angles for this one. Other option is coping the corners. This might be best anyway. Anyone have any advice? Thanks.
A Practical Perfect Wall
  • The New Old Colonial
