Crown Molding Angle inside 90
hacker454 | Posted in General Discussion on December 9, 2002 02:03am
good evening,  I am installing 52 38 crown molding in a square bathroom.  I have done some research but I am at loss here.
The Crown molding is to high for my 8.5 sliding chop saw so I have to lay it flat and I plan on coping the material.  I have had no luck finding the correct Miter Angle for an inside 90 degree angle.  I thought I was in luck when I downloaded an angle chart but I believe the angle the chart is referring to is an outside 90 degree, not a inside 90degree.  I tried a practice piece cut at 31.6 degree(based on the chart) but that leaves a gap at the top. Anyone have any suggestions?
Also, I am installing the 52 angle toward the wall and the 38 toward the ceiling, is this correct?
thanks
Hacker454
    SteveInCleveland | Dec 09, 2002 06:02am | #1
    I had a question about crown moulding angled cuts a few months back.  One gentleman who posts here sent me a link to his site.  Check out josephfusco.com.  Click on the "articles" link, and then the "cutting crown moulding basics".
    Good Luck!
    JDRHI | Dec 09, 2002 06:04am | #2
    See if this helps...
    ...and the moulding is either 38 degrees or 52 degrees.
    J. D. Reynolds
    Home Improvements
    "DO IT RIGHT, DO IT ONCE"
    Edited 12/8/2002 10:52:19 PM ET by JAYBIRD
    goldhiller | Dec 09, 2002 05:57pm | #3
    Here's another contribution .............
    http://www.dewalt.com/us/articles/article.asp?Site=woodworking&ID=2
