CROWN MOULDING: DETERMINING ANGLE OF CUT
SteveInCleveland | Posted in General Discussion on June 5, 2002 03:41am
I am installing crown moulding around the top of some new kitchen cabinets.  I have a Delta Sidekick sliding compound miter saw, so there is no need to cut the crown upside-down since I can cut it while it is laying flat.  The saw is premarked for the angle to cut for 90 degree corners, but I have an angled corner wall cabinet.  Does anyone know the angle I need to cut the crown for these two 45 degree outside corners?  Is there a formula for determining the angle of the cut for common angles?  22-1/2 degrees, etc.
Thanks for the help!
  1. Joe_Fusco | Jun 05, 2002 03:54pm | #1
    steve-o
    Try this page it may be helpful.
  2. LEIGHMORGAN | Jun 05, 2002 05:01pm | #2
    Steve o, the answer is M= 13.6   B=17.9  I recently bought a Bosch miter finder. Look for it in tool crib.            Leigh
    1. Joe_Fusco | Jun 05, 2002 11:08pm | #3
      LEIGH,
      And just what do these number represent?If you are using a 38° crown the settings would be 14.3° miter setting and a 17.55° bevel setting.If you are using a 45° crown the settings would be 16.3° miter setting and a 15.7° bevel setting.That information can be found here.
      Edited 6/5/2002 8:52:37 PM ET by J Fusco
      1. KenHill3 | Jun 05, 2002 11:18pm | #4
        Joe-
        As usual, excellent information and stuff to learn about, all presented clearly and shared freely. You da man!
        Thankyou,
        Ken Hill
        1. Joe_Fusco | Jun 05, 2002 11:26pm | #5
          Thanks Ken.
      2. LEIGHMORGAN | Jun 06, 2002 06:00am | #6
        Joe, I assumed he was using 38 crown.  My numbers were from memory, but surely not more than a half degree off. can you adjust the bevel on your saw within those tolerances.
        1. KenHill3 | Jun 06, 2002 06:11am | #7
          Hi, Leigh-
          On my CMS I can adjust the miter within 1/4 degree- I think it's called a vernier scale. The tolerance for setting up the bevel angle, well......................
          Kern Hill
        2. Joe_Fusco | Jun 06, 2002 07:16am | #8
          LEIGH,
          Yes I can, but that's not the point. If he's using 45° you're more then a 1/2° off. You should have stated what degree crown the settings were for.
          Edited 6/6/2002 12:16:50 AM ET by J Fusco
        SteveInCleveland | Jun 06, 2002 04:03pm | #9
        Hey Joe,
        Thanks so much for the terrific information.  I was able to complete that crown moulding project very quickly last night, without having to waste time trying to figure the precise miter and bevel settings!  Your chart on your website is exactly what I was hoping to find.
        Thanks again!
        -Steve
Picture-Perfect Pergola
