Crown Stapler
dmt | Posted in Tools for Home Building on October 6, 2005 01:55am
I have a Bostitch crown stapler (new purchase). I tried it out today on some small items to see how well it worked. It didn’t. I went through three magazines and found that it it misfired (no staple) every other trigger pull. Read the manual — not enough pressure or air leak — checked, increased pressure, no air leak. By the third magazine, I discovered that if I opened and closed the magazine after every staple, it never missed. I have 15 & 18 GA staplers and have never experienced this problem. Is it me, or is it the gun?
Edit: Forgot to mention — the problem stops about 1/2 way through a magazine.
Edited 10/5/2005 7:12 pm ET by Egret
  1. RW | Oct 06, 2005 03:04am | #1
    I think (operative word) you got a lemon. That said, eventually, that seems to be how they get over time. Didn't look used out of the box, did it?  I think every Bos I ever had crapped out within a year. But I understand. Others cost more.
    artacoma | Oct 06, 2005 04:29am | #2
    I have the bostich narrow crown stapler and every once in a while I get a box of generic staples that just don't wanna slide in the magazine quite right ,also I have to keep the magazine clean becuase the spring that pushes the staples is a little weak.
    Ive had the gun for 7 or 8 years and use it for cabinets and occaasionally to blast down subfloor underlayment. Overall I think I've gotten more than my money out of it.
    regards
    Rik
    1. IdahoDon | Oct 06, 2005 05:59am | #3
      I own a Bostich narrow crown stapler and haven't had any problems.  Unbeknown to me until after the purchase, this stapler is rated for 7/32" crown staples, not 1/4".  Maybe your staples are a bit on the snug side?  I've only used Bostich staples so can't say if mine will shoot 1/4"ers ok or not.
      Cheers,
      Don
  3. davidmeiland | Oct 11, 2005 06:31pm | #4
    Sounds easy. If the slide spring is too weak to push the full clip of staples 'uphill' but works when it's half full, try lubricating the magazine. I use a small bottle of Senco lubricant... it's probably just silicone spray or something similar. Spray a bunch of that in the slide/magazine area and see if it improves. And/or, try a different brand of staples.
      dmt | Oct 12, 2005 12:16am | #6
      Thanks. I'll give it a try.
  4. locolobo | Oct 11, 2005 07:18pm | #5
    I had the same problem
    lubricate the magazine
    If that don't work, you need a new spring for the feeder
    locolobo; Edmonton, AB
  • A Postwar Comeback
  • Natural Simplicity
  • A Grand Rescue on the Coast
