Cultured Stone Installation Tips Needed
| Posted in General Discussion on August 3, 1999 07:34am
How do you maintain a constant joint width with cultured stone? I use a masonary blade to cut it straight, no problems. But how do you nip it and keep the edges looking good? What’s a good method to keep the joints constant?
  1. Sonny_DeRose | Aug 03, 1999 07:34am | #1
    How do you maintain a constant joint width with cultured stone? I use a masonary blade to cut it straight, no problems. But how do you nip it and keep the edges looking good? What's a good method to keep the joints constant?
  2. Guest_ | Aug 03, 1999 07:34am | #2
    Cultured stone is suppose to look like real stone. It's not a perfect science, so rely on your eye, and let them vary very slightly. Make it look real. The techniques you mentioned are fine. Also consider using a 4" grinder for tooling the pieces. Tile nippers work good for removing very small pieces.
Outdoor Lighting
  • A Postwar Comeback
  • Natural Simplicity
  • A Grand Rescue on the Coast
