Cumaru decking, acclimatize
easternbob | Posted in Construction Techniques on November 17, 2010 07:58am
Hope to start installing cumaru decking next week.  Supply says it is supposed to arrive on Tuesday (Nov. 23).  How many days should it acclimatize to our local humidity levels before I state installing (Central NY)?  I will be face screwing with trim head ss screws.  Of course I hope it’s isn’t snowing but that is a seperate matter that we have no control over.
Thanks.
    hammer1 | Nov 17, 2010 10:29am | #1
    There is no need to acclimate exterior decking materials.
    1. calvin | Nov 17, 2010 01:36pm | #2
      Hammer
      I might just add that usually no acclimating is required, but in the case of T&G or real dry / wet decking and the time of year put down might make a difference in how tight you lay it.  There have been tales of buckled decking and shrinkage they claim you could throw a cat through.
  2. DanH | Nov 17, 2010 07:21pm | #3
    One should keep in mind that softwood framing will tend to shrink more than hardwood decking, meaning that the decking could buckle if installed tight.  But any sort of normal deck board spacing should avoid this.
  3. DanH | Nov 18, 2010 07:45am | #4
    Well, they're bringing it in by submarine.   4 days gives time for the sea water to drain off.
Drafting the 2027 IRC
  • The New Old Colonial
