I laid some 4″ walnut flooring about 3 years ago. I applied a vapor barrier under the floor. The house is on a crawl space and the crawl space is insulated at the joists. Also, the crawl space is vented. Every summer my floors start to buckle. The buckling is bad where you can actually feel it as you walk and you can definately see it. BUT, in the winter it lays down flat as a pancake. What is causing this and what can I do to stop it. The house is located in Nashville, Tennessee.
In certain scenarios, flat roofs make more sense than pitched roofs (and vice versa).
James
When did you install the floor-time of year?
What was the moisture content of the flooring?
Is there visqueen over the dirt/gravel in that crawl?
thanks.
If you left a proper expansion gap at the walls and it's still doing this (all else being equal), then I dunno.
Totally out-in-left-field idea: If you didn't leave an expansion gap, you might try removing the baseboard and cut away 3/4" of the flooring at the wall (on the board-width sides, of course, not the long sides). It's an awful lot of work and I doubt any circ or jig saw would get that close to the wall, although a Fein Multimaster should reach (though you might well destroy it trynig to cut that much walnut).
If a larger expansion gap is needed i.e. 1/2" I'd use a toe kick or jamb saw.
Stop venting the crawl space and make it conditioned space.
Assuming all manufactures instructions where followed.
You now need to condition the crawl space.
