Curb and Gutter form building basics.
| Posted in General Discussion on May 18, 2005 06:49am
I’ve got about 150′ of curb and gutter to do and although I’ve done a lot of form work, this is my first shot at curb an gutter. Does anybody have a link to a good source of info on form design. I would just go out an buy the movable forms but I doubt I’ll ever do this again.
Sincerely;
The Tool Guy
  1. brownbagg | May 22, 2005 06:13am | #1
    I wish I could show you but most curb and gutter around here is hand form , no forms. Its poured very dry like a 2 inch slump. stack up with a shovel and then they will have a profile cut out of plywood to cut to shape.
    1. Piffin | May 27, 2005 05:47am | #3
      That is th e way I've seen it, only with a form board for the back heel.
      1. brownbagg | May 28, 2005 05:25pm | #4
        yes, a 1x8 for the heel and a piece of formica type brown board about five inches for toe. stack it up, then screen with a profile board.
        Edited 5/29/2005 12:31 pm ET by BROWNBAGG
  2. JasonPharez | May 22, 2005 07:46pm | #2
    Just find the nearest concrete crew and ask them...most should have some tricks to pass along.
    Jason Pharez Construction
       Framing & Exterior Remodeling
Pressure Washing Made Portable
This electric pressure washer is compact, lightweight, and easy to maneuver.
