Big curve!
PJ
Everything will be okay in the end. If it’s not okay, it’s not the end.
Big curve!
PJ
Prescriptive codes don't address the connection at less common angles, so base the connection off more typical ones using bolts, structural screws, blocking, and steel tension ties.
I told ya to buy that extra couple trusses.
A pessimist sees the difficulty in every opportunity; an optimist sees the opportunity in every difficulty. -- Sir Winston Churchill
that's one boss hog's best jobs! ;-)
m
Probably just a good example of not letting a plumber in with a hole saw.jt8
That's some pretty green framing lumber.
Andy
"It seemed like a good idea at the time"
Rain gutter placement is a real puzzle, too.PJ
Everything will be okay in the end. If it's not okay, it's not the end.
