Curved roof framing
shawncal | Posted in General Discussion on July 16, 2007 09:33am
I am building a traditional arched roof barn home that also has a faux silo attached.  Thanks to FHB articles, I’ve learned how to complete most of the curved framing.  however, I need to construct an arched roof section that will connect the arched (truss) roof to the round-walled silo.  It has me stumped!  Any suggestions on how to do this or information on the subject would be appreciated.
thanks,
shawn
  1. john7g | Jul 16, 2007 10:05pm | #1
    Just saw some niced arched/barrel trusses go into a bank nearby.  Have you ran this past your truss supplier?  It wasn't a perfect arc, but short straight segments of 2x making the appearnace of a smooth curve and looks very good.
    Sphere | Jul 17, 2007 01:54am | #2
    I am picturing a half cylinder ( house roof) horizontallly meeting a full cylinder that is vertical is that correct?
    If so, basically the house roof is "coped" to the circumference of the silo. Draw a scale of both and plot from that, or better, mock it up in miniature first.
    1. shawncal | Jul 17, 2007 02:33am | #3
      Yes, the barn roof is essentially a horizontal half-cylinder (although it is an arch, not a constant-radius cylinder), and the silo is a full vertical cylinder.  However, the two do not actually meet, as the silo stands about a foot away from the barn's wall at its closest point.  Thus, I need to add a "tee" off of the barn roof (which i would like to be an arch as well) that will bridge between the two...
      Shawn
      1. arnemckinley | Jul 17, 2007 03:14am | #4
        oh a tee. i see those all the time.
        seriously a picture or sketch would be great. i'm having difficulty understanding you.
        sounds cool. :)
Podcast Episode 691: Replacing Vinyl Siding, Sloping Concrete, and Flat vs. Pitched Roofs
Listeners write in about ground-source heat pumps and weatherstripping and ask questions about engineered siding, concrete that slopes the wrong way, and why houses have pitched roofs.
  • A Postwar Comeback
