Custom Router Bit Needed
csnow | Posted in General Discussion on September 19, 2005 08:36am
I find myself in need of a custom router bit to reproduce some casing.
Surfing finds dozens of shops who make them.
Looking for any personal recommendations or experience with having custom bits fabricated.
    DDay | Sep 19, 2005 10:19pm | #1
    Whiteside are generally thought of as the best router bits, and they will make custom router bits.  I have no idea of the costs but if you need the bit, you need the bit.  I would also ask this question in the knots forum, some of the cabinet makers might have more experience with this type of question.
    http://www.whitesiderouterbits.com/
    Edited 9/19/2005 3:21 pm ET by DDay
  2. RW | Sep 20, 2005 12:48am | #2
    I don't know the cost either. But worth checking into - depending on the cost of the bit, most millwork places have the ability to make knives. It is possible that having them match your profile with their machinery could be cheaper than buying a specially made bit.
    Sphere | Sep 20, 2005 02:09am | #3
    depending on the profile, you can take a piloted rabbeting bit, that is  HSS, and make a single flute cutter.
    BTDT.
    Slow speed, slow feed..not for miles of trim.
  4. reinvent | Sep 20, 2005 02:18am | #4
    You might consider having a set of moulder knives made (abought $150 for 4" w pair). Would probably be cheaper and the casing could be run in one pass. I could run it for you in my shop either on the W&H or the high end shaper we have in the shop. My shop is located in Union SQ in Somerville.
    The local place I go to get knives made is Atlantic Carbide in Somerville around the corner from HD.
  5. davidmeiland | Sep 20, 2005 04:38am | #5
    Paso Robles Carbide in Paso Robles, CA... I think it's the (805) area
Shoulder Your Buckets
Add a strap for easy carrying and pouring when working with 5-gal. buckets.
