custom siding techniques
| Posted in General Discussion on May 9, 2000 01:55am
Adam Greisz – 04:58pm May 7, 2000 SET
Settle WA
Blind nailed corners add a distinctive touch to a siding job. To achieve this I start with a 2×2 and rip a 1/2″ x 1/2″ rabbit out of one corner. Then I attach a 1 1/2″ x 1 1/2″ piece of flashing to the rabbit with a bead of good caulking and some 3/4″ screws. This allows me to nail the flashing to the corner with no nails through the actual wood corner. For a larger corner I start with a 3×3 or a 4×4 (1 1/2″x1 1/2″ or 2 1/2″x2 1/2″ rabbit respectively. I try to leave one inch standing proud of the sheathing).
Another quality touch that I use is snapping vertical lines at each stud location (I believe nailing to the studs is essential for a premium siding job). When nailing the siding to the house I place my speed square on the snapped line and install the nails(I prefer stainless) in the same location(usually 1 1/8″) at each stud. This makes your nail rows perfectly straight. A small touch that makes for a premium job.
If I am asked to do beveled siding that miters around the corners (semi-transparent or clear) I order the siding in as long a lengths as possible. When I miter around the corner I use the same board, achieving grain matches. In some cases this detail gives the impression that the house is carved from solid pieces of wood. It can give a boat like quality to many siding
  1. Guest_ | May 09, 2000 01:53am | #1
    Adam,
    I admire the attention to quality in your work, It will take you far in this business. Sometimes a tough row to hoe, but a good long term proposition.
    Here in Pa we don't use a lot of wood siding. However, I often use the same techniques in the application of vinyl siding. It really gives a job that fiberglass boat quality. I also color match adjoining pieces of aluminum fascia, making sure to fabricate neighboring pieces from the same roll of coilstock.
    For all you died in the wool breaktimers out there
    b I'm kidding!
    Tom
  2. Adam_Greisz | May 09, 2000 01:55am | #2
    Adam Greisz - 04:58pm May 7, 2000 SET
    Settle WA
    Blind nailed corners add a distinctive touch to a siding job. To achieve this I start with a 2x2 and rip a 1/2" x 1/2" rabbit out of one corner. Then I attach a 1 1/2" x 1 1/2" piece of flashing to the rabbit with a bead of good caulking and some 3/4" screws. This allows me to nail the flashing to the corner with no nails through the actual wood corner. For a larger corner I start with a 3x3 or a 4x4 (1 1/2"x1 1/2" or 2 1/2"x2 1/2" rabbit respectively. I try to leave one inch standing proud of the sheathing).
    Another quality touch that I use is snapping vertical lines at each stud location (I believe nailing to the studs is essential for a premium siding job). When nailing the siding to the house I place my speed square on the snapped line and install the nails(I prefer stainless) in the same location(usually 1 1/8") at each stud. This makes your nail rows perfectly straight. A small touch that makes for a premium job.
