cut baseboard on wall
| Posted in General Discussion on June 5, 1999 08:26am
I have a HVAC friend(don’t hold it against me) who has asked how can he cut existing baseboard to install a register on a remodel, with out removing the baseboard.
I told him that I will ask the All Knowing gang on Breaktime.
  1. Brian_K. | May 31, 1999 11:41pm | #1
    Fein triangle sander fitted with the optional saw blade makes a perfect cut.Use the semented blade to cut right into a corner without hitting the wall or floor. Brian
  2. Guest_ | May 31, 1999 11:48pm | #2
    HVAC guys I know would just kick w/ a steel toe and touch up with a 12" sawzall blade w/ two or three teeth.
    BB
  3. fast3 | Jun 01, 1999 07:01am | #3
    Never tried the Fein tool, but Zip bits make a wood cutting bit that works in any die grinder and doesn't do a bad job. Be sure to wear safety glasses though.
  4. Guest_ | Jun 01, 1999 07:28am | #4
    Carl,
    Shoot a piece of scrap to the baseboard, plumb, on the cut line. Hold a long sawzall blade next to it and sandwich the blade between it and another piece of scrap and shoot the second piece on. Then sawzall out the base, and pull off the scraps.
    Clampman
    1. Guest_ | Jun 05, 1999 08:26am | #6
      *clampman, Hey, I like that one. Ed.
  5. carl_/_olmsted_carpenters_co. | Jun 05, 1999 08:26am | #5
    I have a HVAC friend(don't hold it against me) who has asked how can he cut existing baseboard to install a register on a remodel, with out removing the baseboard.
