Cut ‘n bend rebar
Gene_Davis | Posted in Tools for Home Building on December 11, 2006 11:04am
For concrete foundation walls, we’ve about decided to take it inside and do strictly ICF.  That’ll create a need for handling rebar.
What is your preferred tool for cutting and bending up to a #5 grade 60, and is this electric thing from Hitachi worth anything?
  1. nuvue | Dec 11, 2006 11:12pm | #1
    Hey Gene,
    I do alot of conc. in the tropics and the hitachi is a great tool. DO NOT LET someone try to cut or bend #5 or #6 with it...it is great for sturrups and multiple cuts. Mine has lasted thru the year, we will see it's durability.
    Nelz
  2. nuvue | Dec 11, 2006 11:25pm | #2
    Gene
    Forgot to mention,
    I have an old Oatey manual rebar cutter/ bender that still works great and I use that for the #5 bar. Sometimes we use a metal cutoff saw for big bars also, depends on how much there is to cut.
    To make multiple sturrups I have the Hitachi anchored to a table and set up a pattern for the guys to make the sturrups. I use nails as guides for different patterns.
    Nelz
  3. davidmeiland | Dec 12, 2006 03:36am | #3
    Well, my FAVORITE tool for bending rebar lives over at a place called River Steel. I don't even know what it looks like, but it must be good because if I send a drawing over there I get bent bars right away. If you do some preplanning you can probably order all your bends and just handle straight stuff yourself.
  4. Jemcon | Dec 12, 2006 06:05am | #4
    If you have oxy-acetylene that works good. Use a large cutting tip to cut the heat it cherry red and it bends with channellocks.
    Headstrong, I'll take on anyone!
  5. bake | Dec 12, 2006 06:16am | #5
    Electricians love it when you borrow their conduit benders and use them on rebar!
Outdoor Lighting
