Senior moment here, help required.
Remember there being a circ saw. albeit scary, for cutting subfloor at wall, ie – blade outside.
No luck googling it yet. Help?
The code requires installing an approved material to slow the spread of fire between floors and adjacent vertical and horizontal cavities — here are the allowed materials and required locations.
That sounds like a job for the much-vaunted Fein Multimaster, or one of it's late-arriving copies.
Called a toe-kick saw or something like that, I believe. Something like this: http://www.contractorsdirect.com/Crain-Toe-Kick-Saw
That works, but we are talking lots of large rooms. Currently with a fire and water restoration company. lots of subfloor replacement.
I know I have seen mention made here of a circ saw with the blade offset to the far outside edge of the saw to cut tight to the bottom plate/wall covering. I know it's a scary beast, but just want to know if it's still available anywhere.
Never seen a purpose-made saw like what you need other than the toe kick saws (which probably can do the job).
There have been one or two pictures posted here of "custom" (hacked) saws where one side of the sole plate was cut off and the guard removed. I'm thinking a toe kick saw would be much safer (can you say "OSHA") and probably nearly as fast.
If it's rough work you might consider hacking with a Sawsall:
https://www.finehomebuilding.com/toolguide/product-finder/paws-off-tools-flush-cut-reciprocating-saw-adapter.aspx
scroll down to the bottom of the link
http://www.tiletool.net/Undercut_Saws.asp
now why did the &*%#$@! forum
now why did the &*%#$@! forum software truncate the text of the link??? If the link above doesn't work, try copying & pasting this into your browser.
This one is kind of scary, for a small saw.
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=94626
I'm fairly sure Porter cable make one. Used for cutting the bottom off doors in place.
regards
mark
I pretty sure Blue made his own by breaking the plate on his Makita circular saw. I don't remember what he did about the guard if anything.
There's a picture somewhere.
That's an undercut saw. Not suitable as it has no sole plate or guides for holding it in a shaft-horizontal/blade-vertical position.
GD, you're back in Raleigh, right? Harbor Freight in Durham has this:
http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=94626
