Cutting 20guage Steel Stud
maxchase | Posted in General Discussion on September 28, 2007 07:56am
Other an a chop saw, has anybody been cutting 20 guage steel studs with snips.  If so, what size snips are you using?
I want to avoid a chop saw since it is a residential job and want to avoid the noise and sparks.  I tried normal aviations snips but they seem a bit to smal, I also used a jig saw with a metal blade an it worked well, just a little noisy.
  1. DanH | Sep 28, 2007 07:59pm | #1
    There are bench-style shears made for steel studs, but they probably cost an arm.
    1. DanH | Sep 28, 2007 08:00pm | #2
      Well, only a few fingers: http://fastenmsc.stores.yahoo.net/metalstudshear.html
  2. Hudson Valley Carpenter | Sep 28, 2007 08:15pm | #3
    Is 20ga the lightest in common use? Or is it 22ga?  It's been about twenty years, thankfully, since I had to abuse my senses, working union jobs with that crapola.
    In any case, I recall that the lightest gauge studs were fairly easy to cut with a good quality pair of regular snips.  The right handed snips are a little easier to use, for a right handed person, than the straight snips.  They cut with a small arch which puts the pressure directly on the spot being cut.  I'd say that they're about twenty percent more efficient, easier to use, than straight snips.
    How do I know?  Because I didn't ask that question before buying my first pair.  So I have both types.  Yellow and red grips.
    Edit: Wiss is the company name of the industry standard for quality.  They make a large number of models so do a bit of research and test one or more of them with a piece of stud, before you decide.
    Edited 9/28/2007 1:38 pm ET by Hudson Valley Carpenter
    1. maxchase | Sep 28, 2007 08:30pm | #4
      most lumber yards carry 25 guage.  commercial jobs are typically 20 guage.  i am using 20 guage for the job.  it is much more steardy
      1. FastEddie | Sep 28, 2007 10:51pm | #5
        We used 20 ga for the interior walls, and 16 ga for the exterior non-loadbearing walls that had plywood sheating and brick ties."Put your creed in your deed."   Emerson
  3. RickW | Sep 28, 2007 11:43pm | #6
    I just bought a Milwaukee metal cutting circular saw for cutting studs. You can cut studs and track with it just like cutting 2X4's with a skilsaw.It was around $300.00, but it is worth it!
    Rick W
  4. reinvent | Sep 29, 2007 12:02am | #7
    I would recommend this: http://www.tylertool.com/hicd14mesaw.html
    Noisy yes but no sparks and a very clean cut. Also real handy for cutting angle iron, threaded rod, black pipe, etc. The carbide tipped blades can be sharpened a number of times.
    dedhed | Sep 29, 2007 01:10am | #8
    You can cut them with straight (yellow) aviation snips. cut the two sides andscore accross with a razor knife and bend back and forth
    Sphere | Sep 29, 2007 01:23am | #9
    Get one of them Twin cutters at Lowes, MasterCraft IIRC, about 100 bucks, lemme know if it works.
    "If you want something you've never had, do something you've never done"
  7. ruffmike | Sep 29, 2007 01:40am | #10
    We cut them regularly with regular Wiss snips. If you want you can cut the sides, bend and score it with your rock knife, then bend back and forth a few times and it snaps right off. This works with heavier gauges also.
                                Mike
  8. danski0224 | Sep 29, 2007 02:02am | #11
    This works well, especially for smaller jobs: http://www.malcoproducts.com/products/drywall/src24a.asp
  9. User avater
    coonass | Sep 29, 2007 02:19am | #12
    maxchase,
    I really like my Portaband for this. Gettin' too old to squeeze snips all day.
    KK
    1. BobChapman | Sep 29, 2007 05:00am | #13
      I did a small interior job with steel studs for blocking out closets and the like.  I used my demolition saw with a steel-cutting blade.  Worked fine.  But not a LOT of cuts!
      Bob Chapman
Two Ways to Test Windows
  • The New Old Colonial
