Cutting brick with tile saw
DIY | Posted in Tools for Home Building on July 22, 2005 12:36pm
I need a blade to cut bricks on a MK-100 10inch wet tile saw.  Believe it or not, I read the instruction book and it said all blades “MUST” be smooth and continuous.  I called the company and they said you can use a segmented blade for brick on this machine.    Anybody know of problems using a segmented blade on a tile saw?   Also anybody use the dry abrasive (cheap) blades on this saw?  I usually cut tile and do not do much brick work so I am not too excited to spend $150 on a blade.
THanks
  1. jet | Jul 22, 2005 01:06am | #1
    You want cheep?
    $ 1/2 angle grinder with a diamond blade @ $35.  score all four sides as deep as the blade will go then strike with a hammer.
    "Sir! You are drunk!"
    "Madam! You are ugly, and tomorrow I shall be sober!!"  Winston Churchill
      BillHartmann | Jul 22, 2005 07:19am | #5
      Spendthrift!For $6 you can get a HF blade.
  2. Danusan11 | Jul 22, 2005 01:16am | #2
    I,ve cut 1000's of brick concrete pavers with tile saw, it was a goldblatt don't see how it would matter. I say cut away.
  3. maverick | Jul 22, 2005 05:30am | #3
    I did a fake fireplace and sliced fire brick into 1/2" pieces the long way for the fire box liner. Cut like butter with a regular diamond continuous.
    1. Notchman | Jul 22, 2005 05:39am | #4
      That's because the blade is trained to cut hard sh!t and it doesn't know it's on a tile saw....it can't read.....it just knows that when it starts spinning and starts getting a little shower, it's time to get busy.
      (steel plate or glass may kill it, though.  It relies on YOU to do the right thing).
Podcast Episode 691: Replacing Vinyl Siding, Sloping Concrete, and Flat vs. Pitched Roofs
Listeners write in about ground-source heat pumps and weatherstripping and ask questions about engineered siding, concrete that slopes the wrong way, and why houses have pitched roofs.
  • A Postwar Comeback
