Cutting concrete
| Posted in General Discussion on May 22, 2002 07:47am
I have a slab that is square but the sides are not stright. When I lay down my bottom plate, I have concrete that sticks out. So when I put my siding on it won’t go pass my bottom plate. My question is, is it alright to cut or trim this concrete. It is not much. Thanks Tim
  1. carpenter345 | May 22, 2002 07:53pm | #1
    I would remove it. You want your siding to extend below the sill to keep water from finding a way in.
    Have fun,
  2. calhoward | May 23, 2002 12:57am | #2
    hang your plate over the edge and make the building a bit larger. It's far less work.
  3. FrankB89 | May 23, 2002 03:09am | #3
    If you do want to saw it, I've had pretty good luck using a "Plank Cutter" diamond blade for occasional cutting of masonry blocks and for the situation you describe.  They're 7 1/4 inch, fit a skill saw, cost about $19 and hold up surprisingly well.  They're intended use is for cutting FC board.
    I doubt if they're designed for that use, but I've used one  in a pinch to miter or notch concrete block, trim foundations, etc.  Otherwise, use a diamond masonry blade....about $39 and handy to have around anyway.
     Some people would bitch even if they were hung with a new rope.
    1. JohnSprung | May 23, 2002 03:43am | #4
      Cut off the worst of it like Notchman says, and overhang the rest of it like Cal says.
      -- J.S.
      1. larsen_troy | May 23, 2002 05:09am | #5
        Question:  I have used one of those cheap black masonry blades in the past and was very happy with the results from a $3 blade.  I even put it on a cheap tablesaw and cut slate tiles.
        Is a diamond blade worth the $40?
        1. FrankB89 | May 23, 2002 05:42am | #6
          My experience with the black cheap blades has not been good.  Whether to invest  $19 for a plank cutter or $ 40 for a diamond blade is up to you.  Like I mentioned earlier, I've been pleasantly surprized by the life I got out of the Plank Cutter. Some people would bitch even if they were hung with a new rope.
          1. junkhound | May 23, 2002 05:55am | #7
            Harb. Frt. has $4 diamond blades occasionally, have worked good for me. One of their 7-1/4" $12 diamond blades cut 2.63" deep thru old concrete slab  4 ft long in 5 minutes. They are  cheap 'cause there's only a diamond chip every 1/8-1/4",  but they do cut well.
            If it's going to be covered with siding, just chip it away, a cheap bit in an air impact hammer will make short work of it with a rough surface that you're going to cover anyway.
        2. JohnSprung | May 23, 2002 09:30pm | #8
          The $40 diamond blade will last longer and cut more than $40 worth of the $3 blades.  But that's a whole lot of cutting.  If you're doing a lot, go for the diamond blade.  If you really only need to do a $3 blade's worth of cutting, then that's the way to go.
          -- J.S.
Shoulder Your Buckets
Add a strap for easy carrying and pouring when working with 5-gal. buckets.
