I will be cutting a trough in the concrete floor for plumbing. Can I use my 4 inch grinder with concrete blade or should I rent the big grinder>? jeffysan
The longer length of these 3-in. stair gauges makes it easier to ensure an accurate layout when working with waned lumber.
Why not just a demo hammer. You will still need to break up the big pieces and a lot less dust (but more noise).
Depends on the access, really. Deeper saw cut makes for neater edges as you work in the hole, and for a cleaner surface to drill for dowels. That is, after you use a demo hammer to get the bulk of the material out between the saw cuts.
But, getting a nice big rental was into tight spaces can be a pain. "Beater" circular saw with a concrete blade and much patience can be your friend in those situations. Plenty of opinion on whether to go dry or wet--I prefer wet cutting, but that can be harder to "do" in some situations (like if you don't know where the cutting water will "go" afterwards--it will be drawn, like a magnet, to the most-easily damaged material in about an 1100m radius).
For concrete and angle grinders, my rule of thumb is "not more than about 3-4 tool-lengths" of cut.
I'm with Mac on this one.
Dust is a big problem if you dry cut, but you can abate it somewhat by having someone hold a shop vacum hose next to the saw as you cut.
The deeper you can cut a slab, the less chance of having wild fracture cracks run past the cut line when you break it out. A demo hammer is your best tool for that, unless you are real young and want impress the lady of the house with your sledge-o-matic skills <G>
Dave
Hire it out, it be cheaper, quicker, cleaner. concrete dust aint good for you
You can maybe do it with the grinder, if you plan on making liberal use of a sledge hammer. (Yeah, liberals can use them too ;)
You'll get LOTS of dust, even if you keep things pretty wet, and even a regular circ saw will control the dust a hair better than the angle grinder. But if reasonably available I'd rent a wet saw or one with built-in dust control.
Hiring it out is another option -- in many areas the service is readily available and the rates aren't outrageous.
