Cutting Exposed Rafter Tails
DonCanDo | Posted in Tools for Home Building on March 3, 2005 03:38am
Not exactly rafter tails, but the ends of the “joists” of a pergola that run long.  They will be either 2X6 or 2X8.  The customer wants the ends cut so they’re basically shaped like a roman ogee.  I need to cut about 16 of them.
I could use a jig saw, but I don’t have a really good one (yet).  Even with a good jig saw, I know it’s going to be slow going.  So here are  my questions:  Is there a better way to do this?  If not, what jig saw recommendations can you make?
-Don
  1. gdavis62 | Mar 03, 2005 03:43pm | #1
    I've cut rafter tail ends with a jigsaw, but the blade tends to bend and the cuts all need to be dressed with a belt sander to look good and "square."
    There was an article in a long-ago issue of Fine Homebuilding, showing a guy doing just what you need to do, a pergola, and he was using plywood patterns and a big 3 hp router with a flush trimming bit.
    That's what I would do.  Rough 'em out with the jigsaw, and trim 'em perfectly clean and pretty with the router.
    1. joewood | Mar 03, 2005 05:24pm | #2
      Heyyy, that was an article I wrote quite awhile ago for issue #89. It's up on my website if you'd like to checkitout.
      I still do almost all my corbeled ends (and alot of other stuff) like that. Rough it out with a sabre saw, then use a template and pattern cutting bits. Works like a charm.
      http://www.woodsshop.com/article1.htm
Townhouse Transformation
A sleek, modern redesign maximizes space and light while preserving the building's historical charm.
