Any cut you make is going to have to be trimmed around the window, so I say have at it with a dull framing blade and get some aluminum corner molding.
-Ben
Question: If one synchronized swimmer drowns, do the rest have to drown too?
-Ben
Bad Ass Extension Cords makes quality cords in different lengths and thicknesses, with bright color options as well as customizable branding to keep cords from being lost on the job.
I just checked out a bath renovation job where I'm gonna have to cut a notch [8"x 30"] in a one piece moulded fiberglass tub surround for a window that extends below the top of the surround. Anything I should know before I cut? or just fire up the Homelite? Or can I do this at all?Thanks.
*Don't know much about this but I have seen the plumbers put tape on the surface before cutting a hole for the faucet rough-in.
*I think you'd want to do this with a rotary blade, like a non-toothed grinding blade. I'm thinking the reciprocal motion of a sawzall would probably chip the fiberglas.
*OK!! - Another fine use for the venerable Roto-Zip! Get the right bit for cutting fiberglass and carefully have at it.
*Any cut you make is going to have to be trimmed around the window, so I say have at it with a dull framing blade and get some aluminum corner molding.-BenView ImageQuestion: If one synchronized swimmer drowns, do the rest have to drown too?
*I did this once and just used a utility knife with a sharp blade. But that edge was getting covered by trim. Of course, then I measured to cut out the second notch and realized that it overlapped one of the molded in shelves. Thinking of no way to make that look good I ate the $125 dollars and got a three piece that was flat where I needed it to be.For sale cheap, a one piece tub/shower surround with a chunk cut out of it. :-)Rich Beckman
*ALLAOUND is right. The Rotozip does a great job. Haven't tried it on a beer can yet though.
*you might want to drill a hole at the corners and cut to that.(similar to what's done w/laminate. this keeps the corner from cracking as you move pc around and apply stress to the sheet. best of luck to ya.
