Have been asked to install some glass tile on a backsplash. What is do I need to know about cutting this stuff ? I may be able to locate all cuts at an outlet box so a clean edge might not be too important
anyone?
Glass cutter?
I think a regular score and snap tile cutter will work too.
Water diamond saw.
Yup. Use a diamond tile saw, with H2O, of course. Take 'er slow and easy.
I use a continuous rim diamond blade on a wet saw.
Some glass tiles have a coating on the back, if that gets chipped or ragggedy it can throw off the look of the tile, depending on if the glass itself is clear, opaque, or somewhere in between.
It might help to orientate your tile so your cutting edge goes through the coating and then into the glass. Think of the coating like a veneer on wood, you want your cutting edge to pul the veneer onto the wood, not off of it.
So "it depends".
Thinset. Again, it depends. Normally use white thinset so gray doesn't muddle the color of the glass.
Thinset the wall with the notched side to get the right amount on the wall. Then knock it flat with the flat edge of the trowel. Then set the tile. If you leave the ridges, any ridges that are not fully compressed can show through the glass tile.
It's glass, so obviously it doesn't absorb moisture from the thinset.
Don't use mastic. Mastic can yellow.
John Bridges Forum has a huge folder/posts on glass tiles I read a ways back. You may wanna search it out over there.
http://www.ramdass.org
Thanks to all for the tips, I will see them today, try to take a sample for test cuts
