cutting granite in the granite state
strandomania | Posted in Construction Techniques on June 2, 2010 04:53am
I have a chance to buy some granite countertop at a reasonable price but I would need to cut a sink hole in it. Is it possible to cut this with a diamond blade in a circular saw?
    Jeff_Clarke | Jun 02, 2010 09:54pm | #1
    I would have it wet-cut at a stone shop.   Corners need to be well-rounded.
    1. jwinko | Jun 02, 2010 11:02pm | #2
      sink cut out in granite
      If you are trying to save money and use a top mounted sink, then all you need is a diamond blade and your skilsaw, or a small grinder, but if you want an undermount sink, then call a granite person who has all the tools and can polish the edges.  In Houston they charge around $200.  Good luck
      john
  2. DanH | Jun 03, 2010 08:06am | #3
    Remember, it will be very fragile once the hole is cut.
