In my area we cut them either with a carborundum/chopsaw setup or a hand held power bandsaw (Milwaukee). I was wondering what some of you guys prefer? Stan are you still out there?
We found the brightest, best-performing green laser in a head-to-head test of eight popular models.
How to Install Cable Rail Around Wood-Post CornersRelated Stories
Are you cutting for finish or just getting old stuff out? are you talking wrought iron or steel?
The quickest way to just burn through metal to take it out at the jobsite is a metal cutting blade on a skillsaw. rebar also. This can be dressed up nice with a peanut grinder
If I was cuttin it on the job for a finish, I might use a porta band, or maybe a metal cutting blade with a sawzall. or maybe back in the shop with a cutting torch/grinder
I always carry a makita "peanut" grinder in the truck, very handy
Edited 8/23/2002 9:10:06 AM ET by EXLRRP
They are cast iron and this is a finished stairs application. I might go in and typically install a hundred or so. Some prefer the portaband setup but it kills my back. I'm thinking about a chopsaw setup for ease/speed and measuring jigs.
for prcise mass production of cast iron I think a chop saw is definitely betteryou could use a skilsaw with metal blade for on the job trim if necessary
Edited 8/23/2002 10:01:33 AM ET by EXLRRP
In my shop, I cut a lot of steel flats and rounds using a smallish horizontal bandsaw fitted with a bi-metal blade. This has replaced my hot saw for the most part -- it cuts without a lot of heat, is quieter, and more accurate. I suspect it will cut far better and faster than a portaband. True this is more a shop machine, but it isn't so large that a guy couldn't haul one to a job for a hundred cuts. You can stand straight and even drink coffee while it is cutting. Mine's a Wilton but I think Delta has one too. You don't need a wet cutting saw, dry will do.
ALLEN about a 40% of the balustrades we install nowadays are iron and the primary
tool we use is a chopsaw with a carborundum blade. Of the portable chopsaws
we have a couple of different brands and I can find no particular preference.
The one thing we are careful of however is when using the saw inside we always
put down a sheet of masonite or something for the saw to operate on so it doesn't
burn the floor and shrouds to limit where it throws the metal cuttings. I went
to one job we once did in an almost finished home once and the magnetic charge
that the drywall screws all have had attracted the metal filing from the cut-off
saw so there were all these little black dots all over the wall marking where
all the screws were. It was no problem cleaning them up with just a dust cloth
but it certainly scared me when I first saw it.
While we have a porta-band
saw it's used more for cutting apart (layering) wooden volutes and fitting
and while we could put a metal cutting blade in it to cut balusters I wouldn't
want to work that hard. The other thing I like about the chop saw is you can
roll the end of the cut baluster along the side of the blade to ease the edges
on it which makes insertion into the railings smoother and easier.
Another tool that I find absolutely essential is a hand held grinder both for
shaping or fairing wooden rail (we make most of our own wood rail profiles)
and when it's equipped with a 3/64" thick Walter
Zip Wheel it's great for use as a cut-off tool either for trimming
balusters or making cuts for adjustments in metal scroll work balustrades like
in the photo below ().
I think the grinder with a Zip Wheel would be just as fast
as a porta-band saw (although you will go through a couple of blades on a hundred
baluster job) but it would certainly be a lot easier on your back. The Walter
Enduro Flex Wheels are also the best for cleaning up welds and "sanding"
rough or sharp edges too.
Personally I had been using a DeWalt
DW402 4-1/2 for years but on a project I was installing the other day it
threw the pin that locks the spindle and allows you the change the blade so
I pulled Metabo
W7-115 00715 Quick Change 4-1/2 to use instead and I can't believe what
a pleasure it is to use. The quick change feature on it is absolutely great.
While I will be getting the DeWalt repaired I'm going to make a Metabo my preferred
grinder. The DeWalt's a great tool but comparatively speaking the Metabo is
like driving a Bently .
We also use metal cutting blades in our Tiger
Saws at slow speed too because sometimes you're working in place, in a finished
environment, and you don't want all the sparks that a grinder or chop saw will
throw although we do also carry special protection blankets to protect existing
work and finishes.
We do have horizontal bandsaws in the shop like Jeff does and
while they are more accurate and certainly a lot quieter than either the big
stationary chop saw or the portable ones I still prefer the chop saw or grinder
with a Zip Wheel because they a lot faster and accuracy is certainly more
than close enough. Unlike Jeff however I can't imagine it ever being worth the
time and trouble to drag even a small one on site for just a hundred balusters
given the speed and convenience of the cut-off wheel tools. My van is already
packed with tools too so something would have to come out for a tool that large
to go along for the ride.
"Architecture is the
handwriting of Man." - Bernard
Maybeck.
Thanks to all for the info, it's been very helpfull. Isn't it amazing how iron balisters have become all the rage. Somebody must have put some pics in magazine and it took off from there.
What about glue? We've been using epoxy here........did I mention how bad I hate that stinkin stuff?
Allen you may be right, with more and more iron balustrade jobs showing up
in our portfolio we seem to get even more iron balustrade projects.
"What about glue?" We use West
Systems Epoxy that we'll add 406 Colloidal Silica or dust from the woodwork
to to make it more thixiotropic ( peanut butter like so it doesn't run). I've
heard lots of people complain about the smell of epoxy over the years and I
guess they must be using a different brand because I have absolutely no problem
at all with the smell of the West Systems stuff.
We'll also use Gorilla brand polyurethane
glue too for the snugger fitting assemblies but it's tougher to make it
work without it running down the balusters if you use it to glue balusters into
the railing mortises.
Maybeck.
