cutting rope molding outside mitre
| Posted in General Discussion on June 21, 2003 12:31pm
when cutting an outside mitre with rope molding ,Is there as special way so the profiles line up exactly. I have  always  come close and used my nail set  to roll the mitre. (rope molding used at the bottom of crown).
  1. steve | Jun 21, 2003 02:03am | #1
    sorry its almost imposible
    a little judicious filing and staining will hide the problem unless you want to spend hours matching the profile
    1. chas1 | Jun 21, 2003 03:13am | #2
      thanks  steve you confirmed my belief , I  did  spend an hour playing with the mitre  and only got it looking good by sanding and so filing, thanks for the reply
  2. wrick2003 | Jun 21, 2003 06:37am | #3
    if you were willing to spend about fifteen minutes on each o/s corner, you could try the following:
    cut the miter so that you leave most of the helix.  when you join the miter, this gives you more meat to shape with a file or chisel.
    good luck     rg
