to keep it from splinter do you cut right side or up side down
I talk politics because I hate to drink alone
Up on a tablesaw, down with a handheld, unless its a Japanese style handsaw.
How thin?
I recently used some 3/16" oak ply. After a 3" frayed pass on the table saw I stopped and made the rest of my cuts with a utility knife including a 7" tall miter.
Had I been in shop instead of a driveway I would have fixed a full or partial sheet of 3/4 ply on the saw and ran the thin sheet overtop of it.
edit: right side up
Gord
Edited 10/28/2007 2:57 pm by gordsco
so table saw, right sidecircular saw, upside down..
You got it BB.
Also, if you need to make some cuts with a sabre saw - cut from the back with a regular blade (cuts on upstroke) or get some laminate blades which cut on the downstroke (Lenox makes them for sure, probably others).
Jim
'Zactly, but it helps with either one to score the face with a utility knife before you cut.http://grantlogan.net/
I was born in a crossfire hurricane..........shooby dooby do
I concur.
Thats what I like about you, straight to the point. No flowery rhetoric, or overthinking the problem at hand...
Wait a minute,
I'm rambling
Gord
On quarter inch plywood, like Luan, I just score it with a utility knife--both sides. If it doesn't get cut all the way through it will still snap on the score line, but if you want a neat edge, just keep going over the line with the utility knife until you're through. If this is several sheets, then a saw may be the thing to use. I think a battery-powered saw may splinter less (especially with a plywood blade).
if you use my method with a cir saw lay'n it flat on top of a sheet of 1.5"-2" styrofoam... cut it face down... 100% support...
p
To keep plywood from splintering, use a good, sharp, plywood blade.
To minimize the visibility of the splintering, cut it so the sawblade teeth exit the ply on the "bad" side. That would mean good side UP on a table saw, and good side DOWN if you're using a circular saw or sabre saw.
