Cutting torch for aluminum
Oak River Mike | Posted in General Discussion on November 29, 2006 11:54am
Hey folks,
Going to be cutting up some aluminum sheeting (maybe 1/4″) thick which is the backing for a in-ground vinyl liner swimming pool.  Would a standard cutting torch work very well or would the aluminum dissapate the heat too quickly to allow it to be cut cleanly?
Have to cut it to get it out from the edges of the pool which is long ago abandoned.
Used a torch on standard steel pieces before but wasn’t sure how the aluminum would react.
Mike
    Sphere | Nov 30, 2006 12:06am | #1
    It spatters more, warps more and generally is controlable. I'd opt for a nonferrous cutting blade in a circ saw if ya need a clean edge. WAX is the lube of choice, just a candle aside the spinning blade every now and again.
    I have irriatable Vowel syndrome.
  2. notascrename | Nov 30, 2006 12:11am | #2
    the only way you will cut that aluminum with anything like control is with a plasma cutter. They will cut, steel, stainless steel, aluminum, even cast iron, pretty much anything. Very handy tools. Just plug it in, hook up an air hose and go for it. cuts a narrow kerf 1/16 inch or so. Jim
      Sphere | Nov 30, 2006 12:29am | #3
      You claim that the ONLY way is a plasma?
      Yer nuts.  You have no clue what the alloy is.
      1. junkhound | Nov 30, 2006 12:51am | #4
        Heck, I'd use my backhoe with the thumb and just crush that baby into recyle size balls of Al.
        Notacrename:  too bady you way down in 'bama, or I'd come with the hoe and take it off'en your hands!
          Sphere | Nov 30, 2006 01:22am | #5
          I just reread the post....sounds like a corrogated pool.
          Backhoe/w/thumb....20 minutes into a ball of dollar bills at the scrap yard.
          But , Idiots like me collect old pistons and melt them down into investment castings..I have a sweet old vacuume pump, and lost wax is not a new idea.
          1. dedubya | Nov 30, 2006 03:18am | #8
            WENT by the welding supply store today, miller has
            a small plasma cutter no bigger than half a loaf of bread
            120v/220v 18pds. as Rachel Ray says neato.
          2. joeh | Nov 30, 2006 11:26pm | #10
            And the Christmas price was?
            Joe H
          3. dedubya | Dec 01, 2006 04:04am | #11
            Ya know I didn't even ask - I was actually checking on
            the price of a lincoln :Ranger :welder I saw in their showroom
            10,000 watt generator/ welder powered by a industrial Kohler
            2300.00 on that one.I,ll check tomorrow ,there were times I
            really needed that plasma cutter just not now.
            Sphere | Dec 01, 2006 04:13am | #12
            Hey, I'll get in touch right quick, down with a badassed cold right now...ugghh.
            I have the rocks, just no plan for the roll...I figgure a stacked laid wythe around the wood buner....sorrry, we'll talk later.
        MarkH | Nov 30, 2006 03:10am | #7
        I tried cutting brass with a plasma cutter once.  Burned through it, but no plasma at all.  Steel gets a blazing plasma, I think AL would be like brass.
        1. McMarky | Nov 30, 2006 03:58am | #9
          That is because the oxygen in the air plasma is consuming (burning) the iron in the steel.  Aluminum, like brass, should mostly melt, and the air will remove the molten slag.
  3. McMarky | Nov 30, 2006 03:00am | #6
    A torch will not actually cut aluminum, it will only melt it.  Often this results in a mess.
    An oxygen acetylene torch heats up the steel to the point where a blast of pure oxygen actually burns the iron.
    This is why oxy act torches are only used on iron and ferrous steel.
    An abrasive balde will not work well either.
