I need to purchase another set of dam corners. For some reason NY states stores like Lowes and Home Depot do not stock the stuff. Any suggestions for other stores that might?
Listeners write in about saving frogs, attic ductwork, lime wash, and energy ratings for real estate.
What's a dam corner?
It is called a corner dam or PVC corner that goes over the curb of a shower to make the membrane water tight. They are hard to find.
OK. Check out USG's new shower system. They've got something like this. As does Kerdi.
Keep in mind that, depending on what store you walk into, you maybe shouldn't call them "dam corners". In some stores they'd be "darn corners", while in others they're "#!mfing&*$! corners".
