I recently purchased a Dayton air stapler, model 6w527a at a local yard sale. the first problem is I didn’t get a manual….where can I find one of those? The seller said that it could do sheeting and decking…is that true? What type of staples will fit it? Can I use it for shingles with the right length staple? Any help will be very much appreciated. thanks, Jim.
Listeners write in about changing careers and organizing volunteer builders and ask questions about high humidity, underfloor cooling, and removing ceiling texture.
I recently purchased a Dayton air stapler, model 6w527a at a local yard sale. the first problem is I didn't get a manual....where can I find one of those? The seller said that it could do sheeting and decking...is that true? What type of staples will fit it? Can I use it for shingles with the right length staple? Any help will be very much appreciated. thanks, Jim.
Jim, the "Dayton" name is used for many items sold by W. W. Grainger Co.
Start your search for info on the tool at.
Good luck, Steve
