Dead Receptacle
chuck95 | Posted in General Discussion on October 31, 2006 04:45am
I would like a little advise on how to trace some wire going to a dead receptacle.  Recently a duplex receptacle went dead in one of my bedrooms. I removed the receptacle and noticed that only two wires are connected which tells me that this the last receptacle in the circuit. I’ve reached into the wall to feel which way the wire is heading and noticed that goes off toward an area that has no other receptacles.
My question to the forum is how can I figure out where this receptacle is getting power?  I probably have a disconnected wire in some junction somewhere.  I’d rather not start taking all the ceiling & wall fixtures apart trying to find the errant connection.  Is there an inexpensive wire/circuit tracer available for this?   Thanks for the help!
  1. BryanSayer | Oct 31, 2006 05:12pm | #1
    Did you check that the wire is dead? I had a recepticle just die on me. Even after I replaced it, I have no idea what the problem was.
    The wire may run over and come down from overhead, or even up from below.
    One way to find out what else is on the circuit is to just short the wires and trip the fuse or circuit breaker. There are better ways, I'm sure but it does work. Then you can locate what the most likely feeder is.
    BTW, you might want to check for a GFCI breaker being tripped. I had a light that went out every time it rained. Turned out it was being feed from a CFCI that was at the furthest corner away from the light.
    BillHartmann | Oct 31, 2006 05:40pm | #2
    There was a long discussion about this recently including tracing equipment.
    http://forums.taunton.com/tp-breaktime/messages?msg=80397.1
    Also you did not give any idea of the age of house, construction (number of stories, basement/slab, etc). Or if it has had major remodeling and/or additions.
    A few clues. It might be on the same circuit as a receptacle on the otherside of the wall.
    House built before power drills the wiring usually went up and down. Only had to go through the plates.
    Newer houses receptacle wiring often went around the round through the studs.
    1. chuck95 | Oct 31, 2006 09:00pm | #3
      Thanks for the quick response. This house was built in 1968 so the wires go horizontally through the studs.  That link you sent is a good starting point.
      It looks like if I back feed the dead circuit I can us one of those less expensive tracers that require 120V.  This one is about $70.
      http://www.grainger.com/Grainger/wwg/productIndex.shtml
      1. sledgehammer | Nov 01, 2006 02:05am | #4
        Of course if it's the neutral that is dead, backfeeding will give you a really neat light show.
        When backfeeding dead circuits it is often reccommended to wear brown pants.
FHB Podcast Segment: Embodied Greenhouse Gas Emissions and the Building Codes
