deadbolt 5-1/2″ but door is 3-5/8″
FastEddie | Posted in General Discussion on September 17, 2007 03:41am
Tell the wife it’s her problem.  She should have checked all the dimensions before ordering.  Tell her to authorize a change order for the extra work required to install the customer-ordered parts.  Then start looking for a new place to live.
“Put your creed in your deed.”   Emerson
“When asked if you can do something, tell’em “Why certainly I can”, then get busy and find a way to do it.”  T. Roosevelt
    popawheelie | Sep 17, 2007 04:11pm | #1
    First off, this happens all the time. If it was my problem I'd switch the hardware to fit the doors. Why? Becuase the hardware is lighter.
    Is your wife set on the hardware? That happens a lot too. It's just a door knob. Find door knobs that fit the door and that she likes.
    Gene_Davis | Sep 17, 2007 04:29pm | #2
    Let's see you find all the handleset hardware that is designed for that "standard" 3-5/8" bore spacing.
    Whose "standard" is it?
  3. doorboy | Sep 17, 2007 05:39pm | #3
    Did you order the steel doors "pre-drilled" for hardware? If not, take 'em back and exchange them for single bored units. The jamb prep is more critical than the lock prep on the doors. The wife did nothing wrong here except for buying a handleset she liked.
    "She wrote a long letter, on a short piece of paper." Traveling Wilburys
  4. Hudson Valley Carpenter | Sep 17, 2007 06:31pm | #4
    I would ask DW to return the locksets and choose something to fit.  Or visa versa, return the doors.  I would NOT drill and fill, for a number of good reasons.
