Deck and Cinder Block Wall
NotYoungButStupid | Posted in Construction Techniques on February 11, 2021 02:59pm
I have a hollow cinder block wall to which I want to attach a deck. For multiple reasons I am trying to avoid digging foundation posts right up against the house. (The ones on the other side of the deck will be o.k. to dig and install). Are there any possibilities here on how to attach this girder to house without new posts? Is filling in the cinder block even a option here?
  1. calvin | Feb 11, 2021 03:53pm | #1
    How close can you dig to the house?
    Enough so you can cantilever the frame to the house with no connection?
    While filled block would hold the deck connection “up”, I’d be concerned with force on the block in/out. Horizontal rebar laid in conjunction with bldg the wall might have resisted that force. But then again, never run into that problem nor am I an engineer.
    1. NotYoungButStupid | Feb 11, 2021 04:21pm | #2
      The closest I can dig would probably be 3 feet away and that’s the edge of the hole and not the center. I am estimating a 12”-18” diameter hole will be needed.
    unclemike42 | Feb 11, 2021 05:39pm | #3
    https://www.awc.org/codes-standards/publications/dca6
    (you may have read it)
    https://www.finehomebuilding.com/membership/pdf/385972/021282054.pdf
    has a hint.
    https://www.strongtie.com/screentubes_adhesiveanchoringaccessories/steel_screentube/p/steel-adhesive-anchoring-screen-tubes
    unclemike42 | Feb 11, 2021 05:40pm | #4
    has a hint at the end. adhesive and screen tubes.
      unclemike42 | Feb 11, 2021 05:41pm | #5
      An example of hollow wall anchor screens:
      and you need some adhesive to go with it.
      https://embed.widencdn.net/pdf/plus/ssttoolbox/zjc7nxkcoh/S-A-PG19.pdf?u=cjmyin
      see page 34
      Note that these are not on the approved list, which is included in the fairfax county document mentioned later.
      Hilti screen and adhesive is on the list:
      https://www.hilti.com/c/CLS_FASTENER_7135/CLS_INJECTABLE_ADHESIVE_ANCHORS_7135/r8298802
      https://www.hilti.com/c/CLS_FASTENER_7135/CLS_ANCHOR_RODS_ELEMENTS_7135/r2804
      as is the read head
      https://www.itwredhead.com/products/adhesive-anchors/a7
      https://www.itwredhead.com/Portals/0/Documents/2019%20Catalog/Adhesive%20Anchoring%20Systems/Umbrella%20Inserts%20and%20Screen%20Tubes.pdf
  4. andy_engel | Feb 14, 2021 09:00am | #6
    Building codes prohibit attaching deck ledger to hollow block walls. However, attachment is allowed to a block wall if the cores are grouted solid with concrete. It's all in this document. https://www.awc.org/pdf/codes-standards/publications/dca/AWC-DCA62015-DeckGuide-1804.pdf
      unclemike42 | Feb 14, 2021 09:14pm | #7
      The end of Mike Guerten's article (post #3 above)
      last paragraph in figure:
      "Fairfax County also permits ledgers to be fastened to hollow CMU using adhesive anchors and a “screen” (mesh tube) on the inside to retain the adhesive. Follow the adhesive-anchor-system manufacturer instructions."
      https://www.fairfaxcounty.gov/landdevelopment/sites/landdevelopment/files/assets/documents/pdf/publications/deck-details.pdf
      See page 15 of 28
      The next page identifies anchor sources which are approved. These do not include the ones I pointed to earlier as examples.
      Of course, the code in the jurisdiction of the deck in question applies.
      1. andy_engel | Feb 15, 2021 07:04am | #8
        I'm surprised Fairfax County allows that - They're about the strictest jurisdiction in the country.
          unclemike42 | Feb 15, 2021 12:36pm | #9
          I suspect there were some interesting conversations.
          mikeljon | Feb 15, 2021 01:57pm | #10
          I've had too many CMUs fall apart from putting in tapcons to be able to trust this, no matter the engineering standing behind this.
