deck circa 1987
gzajac | Posted in Construction Techniques on June 14, 2009 04:39am
Everyone
Looking at a deck project, reskinning existing decks over existing 22 year old pressure treated framing. My question, at what point do you consider replacing existing framing, also?
I was going to replace joist hangers, existing ledger bolts, and apply peel and stick to tops of joist, and re-skin.
Existing decks are between 18″ and 9 feet off the ground, and joists are solid. Does the pressure treated material go down hill once it reaches 20 or 25 year guaranty?
Thanks for your thoughts
Greg in in Connecticut
    PaulBinCT | Jun 14, 2009 04:47pm | #1
    Sounds identical to a job I did a month or so ago.  i'm sure there's some reduction in the chemicals over time at the surface but if they're well treated (big if I'm sure) I'd expect they continue to leech perservative for a long time.  In my case, I'd say the vast majority of the framing was fine, but anything that had significant splits etc was replaced.
    PaulB
    http://www.makeabettertomorrow.com
    http://www.finecontracting.com
    1. gzajac | Jun 14, 2009 05:02pm | #2
      PaulI reskinned one about three months ago, and the joists looked as good as they did, when I built it 22 years ago.These are part of a condo project, so I have to estimate the balance of useful life, so they can establish a future reserve amount.Thanks
      for your thoughtsGreg in Connecticut
        PaulBinCT | Jun 14, 2009 05:37pm | #3
        I'd imagine a large part of the servicable life is a function of the preservative, and whether it was applied sufficient to penetrate very deeply.  Maybe cutting one if half will give you some insight?
        Good luck...PaulB
  2. FastEddie | Jun 14, 2009 05:54pm | #4
    Might be worth your time to do a test excavation to lok at the post a foot or so bel;ow grade.  Otherwise you're just guessing.
    1. gzajac | Jun 14, 2009 09:11pm | #5
      FasteddieWe set all the postd on concrete piers 22 years ago, but never used any post anchors though. Deck posts themselves look in real good shape.thanksGreg in Connecticut
  3. Shoemaker1 | Jun 14, 2009 09:25pm | #6
    Guess it depends on how well the cuts were sealed. I have pulled out PT that was good for 90% but the untreated ends rotted just like spruce.
    Do you have access to a non distructive materials inspectors. may cost a few bucks but might bring some peace of mind for all involved.
    Are the old fastners going to be eaten buy the new style PT?
    1. gzajac | Jun 14, 2009 10:43pm | #7
      ShoemakerNew decking will be a composite,no new pressure treated,only going to replace joists as necessary.None of the ends were sealed at the time the deck was built, but they do look pretty solid.ThanksGreg in Connecticut
