Hello all. I am planning to clean and stain a fence around a pool deck, and the deck cleaner warns against coming into contact with metal. There are a hundred or more vertical metal balusters set into pressure treated 2 x 4 railings, and I’m wondering how to avoid getting the cleaner on them. Would the cleaner ( sodium hypochlorite) cause significant damage to the metal balusters, or should I just not worry about it and rinse everything really well? Thanks in advance for any advice.
Performance improvements for the prized homes of an influential developer who wanted us all to be able to own one.
Sodium hypochlorite is chlorine bleach, reasonably safe on most metals. Probably the biggest concern would be that it might cause paint to fade on painted metal, though it could in theory cause rust to appear on bare steel surfaces.
"Wood bleach", on the other hand, often contains oxalic acid, a chemical which miraculously removes rust from steel, but also removes the protective anodizing coating from aluminum. One needs to take considerable care to keep it away from aluminum. And some wood cleaning products may contain potassium hydroxide, a highly corrosive product that will attack most metals.
Of course, it's always wise to test a bit of the product on the proverbial "inconspicuous area" before committing to its use.
Excellent information. Thank you!
Question for the deck cleaner manufacturer.
" the deck cleaner warns against coming into contact with metal"
How do you avoid the nails, screws or the other fasteners holding the decking?
I wondered the same thing.
Being around the causic enviroment of a pool is far more damaging then spraying and rinising witha little bleach.
Makes sense.
