Deck Gutters?
tashler | Posted in General Discussion on July 22, 2009 03:58am
Several years ago Lowes had a product that is installed between the joists of a deck, then run to a gutter at the end of the deck.
The whole idea is to have the water travel somewhere else so that, even in foul weather, under the deck is dry and usable.
Anyone know of any brands of this kind of product, or have any reviews or comments?
Thanks.
Glenn
    IMERC | Jul 22, 2009 04:06am | #1
    not here...
    WOW!!! What a Ride!
  2. Tomrocks21212 | Jul 22, 2009 05:27am | #2
    I've seen it, but I can't remember the name. It was a vinyl product. One of the yards I used to deal with would get it in on a special order, but even the mfr.'s literature warned against using it in areas that had to stay absolutely dry.
    In other words, it leaked. The pix I saw showed a strip, sorta like starter strip for siding, that the pan snapped into, and it looked like the strip would be the major source of leaks.
    I did something similar for a client once. I bent up some pans out of coil stock, nailed them between the joists, and used I&W to counterflash over the joist tops and over the nails. We were on 12" centers, don't know if I'd trust wider joist spacing.
    This was before ICQ lumber, though, to do it now you'd need to isolate the coil stock from the framing.
    Also, my method wouldn't work well for a retrofit.
  3. WINSTALL | Jul 22, 2009 04:04pm | #3
    Dryspace.......... mfg by Timbertech... In the mid-west... it is distributed by Palmer - Donovan.
    As long as GOD makes "bad builders" and rich people... I will have a job
    1. neadvadid | Jul 22, 2009 06:07pm | #4
      Might be what I need. Thanks
    2. tashler | Jul 23, 2009 12:15am | #6
      What a goof! Post #5 is from ME, not neadvadid.Goof!Glenn
  4. john7g | Jul 22, 2009 11:58pm | #5
    in a past home I just hung fiberglass corrugated roofing sheets under the deck.  sloped to ensure drainage they worked great and looked good.
