Deck joist waterproofing?
MBaybut | Posted in General Discussion on December 3, 2013 12:15pm
Hi,
I’m about to start building my deck and was wondering if I could use elastomeric roofing cement to protect the tops of the joist?
Mike
  1. DanH | Dec 03, 2013 06:39pm | #1
    If I were doing it all over again, building an open deck, I'd probably use rubber "peel-and-stick" or some such over the tops of the joists.  However, I suspect roofing cement would cause more problems that it would prevent, by damming up water in spots.
  2. maxwell12 | Dec 04, 2013 05:04am | #2
    Deck joist protection
    I used the narrow rolls of peel and stick sold for window installations on my deck. It was very easy to work.
  3. gfretwell | Dec 05, 2013 10:40am | #3
    Use .6 CCA (or .8 if they have it) rough sawn "dock lumber" from a marine supplier and don't worry about the water.
    I did use the peel and stick to isolate the CaC 4x4 posts from the Simpson clips and all of the CaC framing was done with S/S nails.
    http://gfretwell.com/ftp/Deck%20going%20down.jpg
  4. gfretwell | Dec 05, 2013 10:40am | #4
  5. florida | Dec 06, 2013 08:39pm | #5
    Sure, but you can also staple on strips of felt and accomplish the same thing a lot easier. The peel and stick membranes are nice but very pricey.
  6. MBaybut | Dec 06, 2013 09:59pm | #6
    Thanks All
