Deck Ledger Board (cantilever??)
rickjl | Posted in Construction Techniques on May 7, 2009 11:25am
I have a rotting 10′ x 20′ deck that I am afraid to walk on and just want to replace it.  I need to get a permit and have it inspected and am in the planning process.  The current deck does not meet the county codes.  I don’t think the inspectors are much help until you have the permit but then you are on the clock to get it completed.
I haven’t seen this addressed anywhere.  The 20′ side with the ledger board extends 2 feet past the end of the house (goes over to a patio).  This means the last two feet of the ledger board do not bolt to the house.  Do the beam length / 4 rules apply here?  Do I need a redesign?
  1. rez | May 09, 2009 08:53pm | #1
    Greetings rick,
    This post, in response to your question, will bump the thread through the 'recent discussion' listing again which will increase it's viewing.
    Perhaps it will catch someone's attention that can help you with advice.
    Cheers
    94969.19  In the beginning there was Breaktime...
    94969.1  Photo Gallery Table of Contents
  2. LIVEONSAWDUST | May 10, 2009 07:50am | #2
    well, untill someone more knowledgable comes along,
    my solution would be to either add a post and footing at that location or double the ledger for at least 8' or so.   would also have to increase the strength of the ledger bolts maybe.
    All you can do is submit a drawing and see if they accept it
    Ted W. | May 10, 2009 04:23pm | #3
    I'm in agreement with the previous poster. But that said, have you tried asking BI about it? From my experience, they're usually helpful in these matters even before the permit is issued, and even appreciate that you want to let them in on decissions right from the start.
    ~ Ted W ~
    Cheap Tools! - MyToolbox.net
    See my work at TedsCarpentry.com
